Create Chatbot with Bot Wizard
Bot Wizard allows power users to create a chatbot through Intent Template or Automation Data Table with simple and quick steps.
Basic Steps
Create Chatbot
- Choose either of the methods to create a chatbot:
- Click the start menu
, select Intent-Based Automation > Chatbot Manager, and click +Add Bot.
Note: Accessing the Chatbot Manager requires the Chatbot Management privilege enabled in the System Privilege.
These roles by default have the Chatbot Management privilege: Domain Admin, Power User, and Engineer. - Click
from the task bar and select New Bot.
- In the Create Bot window, enter the Bot Name.
- Select one of the methods:
- Select Automation Data Table. Click Start. See Create Chatbot from ADT for details.
- Select Intent Template. Click Start. See Create Chatbot from Intent Template for details.
- Select Blank Canvas. Click Start. See Create Chatbot in Full Editor for details.
