R12.1 Project-2025Sep08
Configuring Private Key
The following SSH private key types are supported in the system to access your network devices:
  • SSHv1 RSA key
  • SSHv2 RSA key
  • SSHv2 DSA key
  1. Click the Private Key tab.
  2. Click Add to open the Private Key Settings dialog box.
  3. Enter an alias and click Browse to import your SSH private key file.
  4. Enter a passphrase twice if your private key is encrypted.
  5. Click OK.
Repeat steps 2~ 5 to add more entries if required.
Information Tip: You can relate the private key with the SSH public key in the Telnet/SSH Login Tab.
