Configuring Jumpbox
If NetBrain Front Server cannot access your live network directly, you can configure a Jumpbox. The Front Server accesses the Jumpbox first and then retrieves live data via the Jumpbox.
Note: The Jumpbox server is supported only on Linux. Windows-based Jumpbox servers are not supported. |
- Click the Jumpbox tab.
Click Add to open the following dialog box and enter the required information.
Note: When a Front Server is attempting to access the Jumpbox, you will be asked to enter the required credentials of the Jumpbox followed by the CLI indicators.
- If your network devices require special commands to access via Telnet or SSH or require an additional set of credentials, you can click Advanced to configure more settings.
- Click Test to check whether the connection between the Jumpbox and the Front Server is working.
- Click OK.
