Configure Change Analysis Settings
To determine which data types are monitored by Change Analysis, complete the following steps to configure the Change Analysis Settings:
Note: Only users with the Domain Management privilege can modify the CA Settings. |
- Click the start menu
and select Change Analysis Reports.
- In the Change Analysis Report page, click Go To Change Analysis Settings.
In the Change Analysis Settings pane, configure the following settings:
- Check the Enable Change Analysis checkbox to enable the Change Analysis. If not enabled, NetBrain will not monitor or record any data changes for the Change Analysis Report.
Select the data type from the list. See Live Data for more details about the available data.
- Click Save.
