Logo
R12.1-2025July30
Clickable Status Code
You are allowed to click the status code to view the diagnosis details, which is also a key function of intent. You can view more information here, auch as when this intent was executed.
You can open the diagnosis details dialog from the following two entrances:
  • From the diagnosis message in NI results.
  • From the status codes on map data views.
Display Status Codes from Follow-up Intents Together View Intent Result on Map
