Built-in Module Properties
The following table lists the module properties (case-sensitive).
| Property Name | Display Name in Device Details Pane | Description |
| name | Slot# | The modules of a device. |
| type | Module Type | The port count of a module. |
| ports | Ports | The module type of a module. |
| sn | Module Serial Number | The serial number of a module. |
| hwrev | HW Rev | The hardware revision of a module. |
| fwrev | FW Rev | The firmware revision of a module. |
| swrev | SW Rev | The software revision of a module. |
| descr | Description | The description of a module. |
