Built-in Interface Properties
The following table lists the interface properties/attributes (case-sensitive).
Property Name | Display Name in Device Details Pane | Description |
name | Interface Name | The name of an interface. |
ips | IPv4 Address | The IPv4 address of an interface. |
ipv6s | IPv6 Address | The IPv6 address of an interface. |
ipv6LinkLocalAddress | IPv6 Link Local Address | The IPv6 local address of an interface. |
mibIndex | MIB Index | The MIB index of an interface. |
bandwidth | Bandwidth | The bandwidth of an interface. |
speed | Speed | The speed of an interface. |
duplex | Duplex | The duplex of an interface. |
intfStatus | Live Status | The state of an interface. |
macAddr | MAC Address | The MAC address of an interface. |
moduleSlot | Slot# | The module slot number of an interface. |
moduleType | Module Type | The module type of an interface. |
descr | Description | The description of an interface. |
routingProtocol | Routing Protocol | The routing protocol configured on an interface. |
multicastMode | Multicasting Mode | The multicasting mode of an interface. |
mplsVrf | MPLS VRF | The name of the VRF configured on an interface. |
mplsVpn | MPLS VPN | The MPLS VPN configured on an interface. |
inAclName | Inbound ACL | The inbound ACL of an interface. |
outAclName | Outbound ACL | The outbound ACL of an interface. |
mode | Switchport Mode | The switch port mode of an interface. |
vlan | VLAN | The VLAN number that an interface belongs to. |
trunkNativeVlan | Native VLAN | The native VLAN of an interface (switch port). |
trunkEncapsulation | Trunk Encapsulation | The trunk encapsulation protocol of an interface (trunk port). |
ipUnnumberedIp | Trunk Unnumbered IP | The unnumbered IP address of an unnumbered interface. |
