R12.1-2025Jul03
Built-in Data View Templates (DVTs)
The system provides the following built-in data view templates for various purposes and scenarios, including routing and switching, security, quality of service, high availability and so on.
CategoryBuilt-in DVT NameBranch CriteriaSupporting VariablesDrill Down Actions
Cisco ACIFabric Health and Faults [Cisco ACI]
- Traditional Device
- Device Type contains Cisco ACI APIC; Cisco ACI Leaf Switch; Cisco ACI Spine Switch
Device Level:
- fault_details1)
- fault_critical
- health_timestamp
- health_change
Device Level:
View the Cisco APIC Faults Online Guide1)
Fabric Underlay Connections [Cisco ACI]
Device Level:
- LLDP_Detail
- CDP_Detail
- port_channel_detail
- vpc_detail
Template Level:
View the Introduction to Cisco ACI
Logic Node View [Cisco ACI]
Branch: BD
Device Level:
- tn_name
- bd_mac
- subnets
Branch: Contract
- Contract
Device Level:
- provider_epg
- consumer_epg
- contract_detail
- filters_detail
Branch: EPG
- EPG
Device Level:
- tn_name1
- ap_name
- ep_detail
Branch: L2Out
- L2Out
Device Level:
- BD_extended
- node_intf_table1
Branch: L3Out
- L3Out
Device Level:
- ospf_info
- node_intf_table
High AvailabilityHSRP Overview
- Traditional Device (IPv4 Interface)
- Config File contains 'standby' and Device Type contains Cisco IOS Switch; Cisco Router
Device Level:
- hsrp_groups1)
- ip_int_brief2)
Interface Level:
- group1
- authentication
- priority
Template Level:
- Compare the Configuration File in two data sources
Understand and Troubleshoot HSRP Problems in Catalyst Switch Networks
- View the Spanning Tree Overview
Device Level:
- Execute CLI Commands show standby; Ping the device1)
- Execute CLI Commands show ip int brief and show ip int | in line|list; View the ARP Table2)
Quality of ServiceQoS Overview
- Traditional Device (IPv4 Interface; Physical Interface)
- Config File contains 'service-policy' and Config File contains 'policy-map', and Device Type contains Cisco IOS Switch; Cisco Router
Device Level:
- service_policy1)
- class_map2)
- mls_qos_intfs
Interface Level:
- direction
Template Level:
View Enterprise QoS Design
Device Level:
- Execute CLI Commands show policy-map1)
- Execute CLI Commands show class-map2)
RoutingEIGRP Overview
- Config File contains 'router eigrp' and Device Type contains Cisco IOS Switch; Cisco Router
Device Level:
- eigrp_neighbor_detail1)
- eigrp_intfs (paragraph) 2)
- RouteTable3)
Interface Level:
- peers (int)
- split_horizon (string)
- pending_routes (string)
Template Level:
- Show log include INPUT [Cisco IOS NXOS ASA]
- View the EIGRP Troubleshoot Guide
Device Level:
- Execute CLI Commands show ip eigrp neighbor detail; Ping the device; View the MAC Table1)
- View the ARP Table; Execute CLI Commands show ip eigrp interface2)
- Execute CLI Commands show ip eigrp topology3)
IP BGP Overview
- Config File contains 'router bgp' and Device Type contains Cisco IOS Switch; Cisco Router
Device Level:
- rid
- bgp_neighbors1)
- bgp_filter_detail2)
- bgp_rib_failure3)
Template Level:
Troubleshoot BGP
- Apply DVT IP BGP Prefix Instance
Device Level:
- Ping the device; Use Traceroute to discover and map a routing path; Execute CLI Commands show ip bgp neighborsshow tcp brief all1)
- Execute CLI Commands show ip bgp neighborsshow access-listshow ip prefix-list, and show route-map2)
Understand BGP RIB-failure3)
Device Level:
- bgp_paths1)
- RouteTable
Template Level:
Troubleshoot BGP
Device Level:
- View the BGP Advertised-route Table1)
- Execute CLI Commands show access-listshow ip prefix-list, and show route-map2)
ISIS Overview
- Config File contains 'router isis' and Device Type contains Cisco IOS Switch; Cisco Router
Device Level:
- clns_neighbors1)
- clns_interfaces2)
- level_lsp_database3)
- isis_protocol_process4)
Interface Level:
- level_1_metric
- level_2_metric
- l1_adj_count
- l2_adj_count
Template Level:
- Compare the Configuration File and Route Table in two data sources
Device Level:
- Ping the device; View the ARP Table; Execute CLI Commands show isis neighbor1)
- Execute CLI Commands show clns interface2)
- Execute CLI Commands show isis database3)
- Execute CLI Commands show isis process4)
MPLS L3VPN
- Config File contains 'vpnv4' and Does not contain 'route-reflector-client'; Device Type contains Cisco IOS Switch; Cisco Router
Device Level:
- rd (string)
- exp_map (string)
- imp_map (string)
- interface (paragraph)1)
Template Level:
Troubleshoot the MPLS VPN
Device Level:
- Show log include INPUT [Cisco IOS NXOS ASA]; Show run section INPUT [ Cisco IOS NXOS ASA]; Execute CLI Commands show ip protocols vrf and show ip vrf interface1)
Multicast Overview
- Config File contains 'ip pim' and Device Type contains Cisco IOS Switch; Cisco Router
Device Level:
- pim_neighbors1)
- pim_intf2)
- rp_mapping3)
- igmp_groups4)
Interface Level:
- version
- dr_priority
- dr1
- nbr_count
Template Level:
Troubleshoot Multicast
- Compare Configuration File in two data sources
Device Level:
- Execute CLI Commands show ip pim neighbor; View the Route Table1)
- Execute CLI Commands show ip pim interface2)
- Execute CLI Commands show ip pim rp mapping and show access-list3)
- Execute CLI Commands show ip igmp group4)
OSPF Overview
- Config File contains 'router ospf' and Device Type contains Cisco IOS Switch; Cisco Router
Device Level:
- ospf_nbrs1)
- ospf_intf2)
- ospf_process3)
- RouteTable4)
Interface Level:
- cost
- nbrs_fc
- intf_state
Template Level:
Troubleshoot OSPF
Device Level:
- Ping the device; Execute CLI Commands show ip ospf neighbor detail1)
- Execute CLI Commands show ip interface briefshow ip ospf interface, and show ip int | in list|line2)
- Execute CLI Commands show ip ospf and show ip ospf database self-originate3)
- Execute CLI Commands show ip route summary and show ip route ospf; Show ip route INPUT [ Cisco IOS NXOS ASA]4)
SecurityAccess List [Cisco IOS]
- Config File contains 'access-list,' and Device Type contains Cisco IOS Switch; Cisco Router
Device Level:
- acl_list1)
- acl_detail
- intf_table2)
- ACL Tips
Interface Level:
- in_acl
- mtu
- out_acl
- nat
Template Level:
Troubleshoot Cisco ACL
Device Level:
- Execute CLI Commands show access-list1)
- Execute CLI Commands show ip interface2)
SwitchingMPLS LDP
- Config File contains 'mpls ip' and 'ldp'; Device Type contains Cisco IOS Switch; Cisco Router
Device Level:
- ldp_id (string)
- ldp_authentication (paragraph)
- ldp_nbrs (paragraph)1)
- mpls_ints (table)
Template Level:
Troubleshoot MPLS LDP
- Compare data in two data sources
Device Level:
- Show log include INPUT [Cisco IOS NXOS ASA]; show run section INPUT [ Cisco IOS NXOS ASA]; Execute CLI Commands show run | i router-id, show tcp brief all, show mpls ldp discovery, and show mpls ldp neighbor1)
- Config File contains 'switchport' and Config File contains 'spanning', and Device Type contains Cisco IOS Switch
Device Level:
- root_bridge
- spanning_tree_root
- vlan_intfs
- stp_features
Template Level:
- Compare the Configuration File and STP Table in two data sources
- View the Spanning Tree VLAN Instance
- Traditional Device (Physical Interface)
Device Level:
- bridge_address
- bridge_priority
- stp_vlan
Interface Level:
- role
- type
- cost
N/A
VMwareInfrastructure View [vCenter]
Branch: Legacy
- Device Type contains NSX Controller; NSX Distributed Logical Router; NSX Edge Security Gateway; NSX Manager; VM Host
Device Level:
- ESXi Host Name
- Memory Size
- vCPU Number
- UsedStorage_MB
Interface Level:
- Connected
- Start Connected
N/A
Branch: VDS
- Vmware Distributed Virtual Switch (Port)
Interface Level:
- Port Group
- State
- Connectee
- Vlan
Operation View [NSX-V]
Branch: Branch1
- Device Type contains NSX Distributed Logical Router; NSX Edge Security Gateway
Device Level:
- edge_status (string)
- ha_state (string)
- publish_status (string)
- system_status (string)
N/A
Branch: Branch2
Device Level:
- status (string)
- nodeFailoverReady (bool)
- connectivity_table (table)
Branch: Branch3
- Device Type contains NSX Manager
Device Level:
- componentsByGroup_SYSTEM_components
- componentsByGroup_COMMON_components
Operation View [vCenter]
Branch: Branch1
Device Level:
- overallStatus (string)
- overallCpuUsage (int)
- hostMemoryUsage (int)
- guestHeartbeatStatus (string)
Interface Level:
- status (string)
- startConnected (bool)
- connected (bool)
N/A
Branch: Branch2
- Device Type contains vSphere Distributed Switch
Device Level:
- hosts_status_table
Interface Level:
- intf_status (string)
GenericInfrastructure View
Branch: ACI
- Fabric Node
Device Level:
- Node Id
- Model
- Serial Number
- Version
Template Level:
- Monitor the overall health of all devices via SNMP
- Learn more about how to use NetBrain
Device Level*:
- Ping the device; Use Traceroute to discover and map a routing path1)
Branch: Legacy
- Device Main Type contains Router; L3 Switch; Firewall; WAN Optimizer; LAN Switch; Load Balancer; Call Manager; WAP; WLC
Device Level*:
- Mgmt IP1)
- Model
- Serial Number
- Site
Network Table View
Branch: Legacy
- Device Main Type contains Router; L3 Switch; Firewall; WAN Optimizer; LAN Switch; Load Balancer; Call Manager; WLC
Device Level:
- NDPTable1)
- RouteTable12
- ARPTable13)
- MACTable14)
Template Level:
- View the training video to see how NetBrain delivers deeper network visibility, faster troubleshooting diagnoses and enhanced collaboration within IT teams
Device Level:
- View the NDP Table; Compare the NDP Table in two data sources1)
- View the Route Table; Compare the Route Table in two data sources2)
- View the ARP Table; Compare the ARP Table in two data sources3)
- View the MAC Table; Compare the MAC Table in two data sources4)
Overall Health Check
Branch: CiscoASA
- Device Type contains Cisco ASA Firewall
Device Level*:
- one_min_cpu_usage1)
- used_mem_utl2)
- failover_unit3)
- failover_interfaces4)
Interface Level:
- input_errors (int)
- crc (int)
- output_error (int)
- collections (int)
- one_min_input_rate_pkts
- one_min_output_rate_pkts
- one_min_drop_rate_pkts
Template Level:
- Show run section INPUT [ Cisco IOS NXOS ASA]
Device Level*:
- Execute CLI Commands show cpu usage1)
- Execute CLI Commands show memory2)
- Show log include INPUT [Cisco IOS NXOS ASA]3)
- Ping the device; Execute CLI Commands show failover4)
Branch: CiscoIOS
- Device Type contains Cisco IOS Switch; Cisco Router
Device Level:
- intfs_table
- five_min_cpu_usage
- mem_util
- cpu_table
Interface Level:
- input_errors (double)
 - crc (int)
- output_error (double)
- collisions (int)
- mtu (int)
- duplex (string)
- tx_load (int)
- rx_load (int)
