Apply Data View Template to Visualize More Physical Network Data
To visualize more physical network data on a map, including topology, IP address, and configurations, you can apply a data view template.
Prerequisites:
Make sure the Benchmark task is properly configured to use Built-in Data View Templates.
Follow the steps below to apply the data view template to your map:
- On a context map, select Data View to open the Data View pane.
- In the Data View pane, navigate to Built-in Data View Templates > Sample DVT > Infrastructure View.
- Click Apply to display the selected data on the map.
