Application Assurance Module
Application Assurance Module (AAM) enables you to manage traffic paths based on applications and verify the application paths periodically to detect possible network changes and ensure application consistency.
Information Tip: To use Application Manager, you need to purchase an AAM license. Otherwise, you cannot open this manager.
Main UI and Use Flow
Graphical user interface
The following is a recommended flow for verifying paths in batches in the system:
  1. Define Applications
  1. Verify Applications
