Viewing Plugin Execution Status and Logs
After executing a plugin, you can view the execution status and logs.
As an additional operation of a scheduled task, the status of a plugin impacts that of the scheduled task as a whole.
  • Impact to Scheduled Plugin Status:
    Plugin  Status
    (All Plugins) SucceededSucceeded
    (All Plugins) FailedFailed
    (Some Plugins) Succeeded
    Succeeded with warning
  • Impact to Benchmark or Discovery Status:
    Plugin StatusBenchmark/Discovery Status
    (All/Some Plugins) FailedSucceeded with warning (if the left modules of the benchmark/discovery succeeded.)
    (All Plugins) SucceededDepend on the status of other modules
Viewing Plugin Execution Logs
Proceed with the steps below to view the execution logs of a plugin in a scheduled task:
Information Note: The printed execution logs of a plugin depend on the log definition in your plugin script.
Example: View the plugin logs in a benchmark task.
  1. On the Domain Management page, click Schedule Task.
  2. On the Schedule Discovery/Benchmark tab, right-click a benchmark task and select View Result.
  3. In the View Log pane, click the icon in the Log column.
  4. View the plugin logs in the Plugin Log pane.
