View ACI Network Structure by Tenant
By following the steps below, you can view the detailed information about a tenant (or VRF) in an ACI fabric:
  1. Select Network in the left pane of your NetworkBrain desktop.
  2. In the Network pane, select Cisco ACI in the Category field.
  3. In the View field, select Network Centric > Tenant View. The ACI data model in NetworkBrain is organized in this order: Single Site > APIC Domain > Tenant > VRF > EPG (Endpoint Group) > Endpoint.
  4. Click a VRF node. You can view the overlay/underlay context map of this VRF.
Information Tip: For more context maps supported under the Tenant View, see Context Maps for details.
Overlay Topology
The overlay topology represents the logical relationship among VRF > Subnet > Endpoint, including:
  • The connection of this VRF to an external network as well as the relevant external nodes.
  • The mapping of Bridge Domain (in this VRF) to VLAN and subnet.
  • Endpoints in an EPG.
The following figure displays the overlay topology of a VRF node.
Underlay Topology
The underlay topology represents the physical resources occupied by a tenant, including:
  • All IPN/ISN nodes in the VRF
  • Spine and leaf switches that belong to this VRF
  • L3 Out and L2 Out switches in the VRF
  • Connectivity of these nodes
NetworkBrain currently provides two different underlay structures of a VRF node:
  • Multi-Pod deployed in a single Data Center (direct IPN connection among multiple Spines)
  • Multi-Pod deployed across different Data Centers (indirect IPN connection among multiple Spines or ISN connection among Multi-Site)
Information Note: Indirect IPN connection can refer to an L3 Network or MPLS Network.
The following figure shows the underlay structure of direct IPN connection between two Spines.
