Verify Application
You can verify application paths in a runbook and run Qapps, CLI command, or other automation to troubleshoot upon path changes.
  1. On a map, open a runbook and add a Verify Application node to the Runbook.
  2. Click the Verify Application node and add the application paths.
  3. Click Run to calculate and verify the paths.
  1. Right-click a verified path with changes and draw the path on a map.
  2. Add Qapps or other actions you want to run for the application paths.
