Comparison Results
The identified changes in comparison results are categorized as follows:
Category | Description |
Added | The data only exists in the second data source or period. |
Modified | The data exists in both the first and the second data source or period but has changed. |
Removed | The data only exists in the first data source or period. |
Equal | The data exists in both the first and the second data source or period, and no changes occur. |
Note: The comparison results for the same device and data type may be different if you swap Dataset 2 and Dataset 1 during the comparison because the Comparison feature takes Dataset 2 as a reference and uses Dataset 1 to compare with it. For example, a comparison result shows that a route entry has been added, but it will show removed when you swap the two data sets. |
