Use Map as a Single Pane of Glass
NetworkBrain dynamic map versus the static network Visio Map is like Google Map versus a printed street map. Different layers of rich data can be displayed on the map, such as the data from configurations, CLI commands or third-party systems. These data layers are organized in the form of Data Views which replace different sheets in a Visio document.
