Use the Data View Template
On-Demand Data Overlay
  1. From the NetworkBrain Desktop Management UI, open the desired map.
  2. Under the Dynamic Data View tab, search for [PRTG] Monitoring Device and Interface Sensor Data.
  3. In the Preview – Data View Template dialog, click Apply.
  4. On the NetworkBrain map, confirm that the Cache/Live data source switch is set to Live.
  5. Confirm that the objects (devices and interfaces) are properly instrumented with the expected PRTG data.
    Information Note: Overlay of the PRTG data may take seconds-to-minutes to complete and refresh depending on the number of devices on the map.
Schedule Data Import from PRTG
  1. In the NetworkBrain Domain Management page, navigate to Schedule Task.
  2. Click on Schedule Data View Template/Parser, then click on Add Task.
  3. In the Add Task dialog, specify the frequency for which to import device and interface data from PRTG.
  4. Click on the Device Scope tab, then click the Device Group radio button. Add each device group created as part of the integration to limit the device scope of the available devices.
  5. Click on the Select Data View Template/Parser tab, click on Add and search for [PRTG] Monitoring Device and Interface Sensor Data.
  6. Click Submit to create the scheduled task for PRTG data import to NetworkBrain.
    Information Note: The PRTG data will not be available on the map until after the first time that the scheduled task has completed execution.
Troubleshooting
If there are any problems encountered during the deployment or integration of NetworkBrain with PRTG, contact NetBrain Support at [email protected].
