Logo
Understand Path Results and Detail Pane
After the path calculation, you may want to know more details, for example, whether the path is calculated successfully, the path logic, etc. These can be viewed in Path Result and Path Details Pane. You can also view Path log to get relevant data.
View Note Summary View Path Results and Details
