Test the Open Driver
  1. Click and select Open Driver Manager.
  2. In the Open Driver Manager window, select and click the Open Driver.
  3. Click Test.
  4. On the Select Device window, select the device you would like to test on. Click OK.
  5. The execution log will be displayed.
  6. Click View Results once the test ends.
  7. Information Note: The test result does NOT have an impact on the device.
