Run the Open Driver
  1. After testing the Open Driver, you can apply the Open Driver to other qualified devices.
  2. Once the Open Driver is enabled, it will be executed automatically in the next benchmark task.
    Information Note: Open Driver will NOT be executed during discovery.
    Information Note: Multiple ODs per device are executed in ascending chronological order.
  1. You can check if the Open Driver successfully fixes the data accuracy issues.
Example:
To see if the serial number is filled in after the Open Driver is executed:
  1. Navigate to the device's Device Details Pane.
  2.  On the Properties tab, click Device, and view the Serial Number.
  3. Open Data Accuracy Discovery, click Re-validate.
  4. No errors are generated. The serial number issue is fixed.
  5. Information Note: The error will be cleaned automatically after the next scheduled platform validation task execution.
