Supported Azure Network Objects
The Azure support mainly focuses on the networking objects and the pertaining objects. The following table outlines all supported Azure networking objects:
| # | Icon | Object Name | Supported TechnologIES | Map | Topology | Path | Unsupported Features |
| 1 | ![]() | Azure Tenant |
| Yes | Yes | No | |
| 2 | ![]() | Azure Subscription |
| Yes | Yes | No | |
| 3 | ![]() | Azure Region |
| Yes | Yes | No | |
| 4 | ![]() | Virtual Machine (VM) |
| Yes | Yes | Yes | |
| 5 | ![]() | Virtual Network (VNet) |
| Yes | Yes | Yes | |
| 6 | ![]() | Azure Subnet |
| Yes | Yes | No | |
| 7 | ![]() | VNet Peering |
| Yes | Yes | Yes | |
| 4 | ![]() | Virtual Network Gateway (Vpn/Expressroute Gateway) |
| Yes | Yes | Yes | |
| 5 | ![]() | Azure Load Balancer (Public) |
| Yes | Yes | Yes | |
| 6 | ![]() | Azure Load Balancer (Internal) |
| Yes | Yes | Yes | |
| 7 | ![]() | Azure NAT Gateway |
| Yes | Yes | Yes | |
| 8 | ![]() | Azure Firewall |
| Yes | Yes | Yes | |
| 9 | ![]() | Azure Application Gateway |
| Yes | Yes | No | OSI Layer 7 Path (URL/Http/Https) |
| 10 |
| Network Virtual Appliances (ASAv, CSR1000v, Vedge Etc.) |
| Yes | Yes | Yes | |
| 11 | ![]() | Azure Virtual Wan |
| 12 | ![]() | Azure Virtual Hub (VHub) |
| 13 | ![]() | Azure VPN Gateway (VHub) |
| 14 | ![]() | Azure ExpressRoute Gateway (VHub) |
| 15 | ![]() | Azure Microsoft Enterprise Edge Router (MSEE) |
| 16 | ![]() | Internet Cloud |
| Yes | Yes | Yes |
| 17 | ![]() | MPLS Cloud |
| Yes | Yes | Yes | |
| 18 | ![]() | Azure Service Endpoint |
| Yes | Yes | Yes | |
| 19 | ![]() | Azure Private Endpoint |
| Yes | Yes | Yes | |
| 20 | ![]() | Azure Private Link Services |
| Yes | Yes | Yes | |
| 21 | ![]() | Azure Storage Account |
| Yes | Yes | Yes | |
| 22 | ![]() | Azure Cosmos DB |
| Yes | Yes | Yes | |
| 23 | ![]() | Azure Database for MySQL |
| Yes | Yes | Yes | |
| 24 | ![]() | Azure Database for PostgreSQL |
| Yes | Yes | Yes | |
| 25 | ![]() | Azure Database for MariaDB |
| Yes | Yes | Yes | |
| 26 | ![]() | Azure Database for SQL Server |
| Yes | Yes | Yes |
