Splunk App
Splunk is a software platform for searching, monitoring, and analyzing machine-generated data. It helps organizations gain insights from large volumes of data generated by various sources, including:
- IT infrastructure: Logs, events, performance metrics from servers, networks, applications, etc.
- Security systems: Security logs, intrusion detection data, malware alerts.
- Business systems: Web server logs, CRM data, point-of-sale transactions.
- IoT devices: Sensor data, machine logs, operational metrics.
The key features of Splunk are as follows:
- Data ingestion: Splunk can ingest data from diverse sources in various formats, including structured, semi-structured, and unstructured.
- Search and querying: Powerful search engine allows users to easily query and filter data using a specialized language.
- Visualization: Dashboards and charts help visualize trends, patterns, and anomalies in the data. Alerts and reporting: Users can set up alerts for specific events and generate reports based on their queries.
- Machine learning: Splunk offers AI-powered features for anomaly detection, threat hunting, and predictive analytics.
Splunk can be used for 1) IT operations monitoring and troubleshooting; 2) Security incident and event management (SIEM); 3) Log analysis and forensics; 4) DevOps and performance monitoring; 5) Business intelligence and analytics; 6) Compliance management and reporting. Overall, Splunk is a powerful platform for unlocking the value of machine-generated data, helping organizations gain insights, improve operational efficiency, and make data-driven decisions.
Prerequisite: Before Splunk and NetworkBrain Integration, verify that NetworkBrain and Pplunk can be reachable from each other. By default, if there is a port for communication. It should be allowed. |
The support for runbook-triggered automation and next-gen TAF automation from the Splunk app is available. For each alert in the Splunk, the user can choose the required networkbrain action after installing the networkbrain splunk app in the Splunk.
