Specify Data Source When Installing Resources via NetworkBrain Download
Installing Resources via NetworkBrain Download is the primary method for initiating installed resources (for more information, see Install and Reinstall Task). You can specify the data source for these resources during library installation. To facilitate this, Data Source options are provided:
  • Use settings in the selected tasks (default option): The data source configured for the resources within the task is used.
  • Use Live Data / Cached Data / ADT Dataset: If the default data source at the domain level is enabled and configured, this option is selected automatically. The data source for the resources in the task will align with the domain-level configuration, overriding the data source settings predefined in the tasks. You can modify data source settings if needed.
