Set up the API Server
Create a LogicMonitor API Server:
  1. Pre-requisites
  2. Create LogicMonitor API Server Connection
Pre-requisites
Network Connectivity
ClientServerProtocol
NetworkBrain Front ServerLogicMonitor EndpointHTTPS
User Account and Privileges
ApplicationUser AccountRequired Role Assignment(s)
NetworkBrainRequiredSystem Admin
LogicMonitorRequiredSufficient access to the expected monitor metrics data
Information Note: If the environment has been deployed with multiple Front Servers, repeat this section for each of the Front Servers.
  1. Using a web browser, login to the NetworkBrain Desktop UI using the System Admin credentials.
    • http://<NetworkBrain Web Server IP>
  2. Navigate to the NetworkBrain API Server Manager.
    • Domain Management > The Start Menu > API Server Manager
  3. In the API Server Manager screen, click Add.
  4. Complete the Add API Server dialog screen as follows:
    • Server Name: LogicMonitor API Server <Front Server>
    • Description: LogicMonitor
    • API Source Type: "LogicMonitor API Adapter"
    • Endpoint: LogicMonitor instance endpoint (ex "https://192.168.28.253:8089")
    • Username: LogicMonitor account's username
    • Password: LogicMontior password
    • Front Server/Front Server Group: Select FS/FSG which would have reachability to LogicMonitor instance endpoint
  5. Click Managed Devices: 0 to assign Splunk Search enabled devices to this API Server.
    • Click + Device.
    • Select "Device Type" radio button.
    • Select All Device Types.
    • Click ">>", then click OK two times to save the device assignment.
  6. Click Test to initiate a connectivity test between the NetworkBrain front server and the LogicMonitor instance configured.
