Select and Preview Dataset
The created datasets can be used for intent creation, intent decoding, intent replication and intent execution. To facilitate understanding and learning, the system provides a common dialog for selecting an ADT dataset as shown below.
  1. When the Select ADT Dataset dialog opens, the untagged dataset columns and tagged datasets in all ADTs are listed. The dataset in this dialog is represented by tag names if it has tags. Otherwise, it is displayed by the dataset column name.
  2. Click the  icon to view the dataset details.
