Save as Runbook Template
To share knowledge with junior network engineers, you can save a golden runbook as a runbook template.
- Click the
icon to select Save as Template.
- Define your runbook template and template variable in the runbook template editor.
- After definition, click Save and select a location for the template.
- Click Runbook on the taskbar and navigate to All Runbook Templates to browse the saved template.
