Rebuild Topology
The system provides you with two methods to rebuild topology and keep all topology links up-to-date when your network changes.
Auto-rebuild a Topology Type
IPv4 L3 Topology is built automatically after Live Network Discovery and scheduled discovery tasks. You can also customize whether to build IPv4 L3/IPv6 L3/L2 topology and L3 VPN tunnel automatically during a scheduled benchmark task. See Benchmark Task Settings for more details.
Manually Rebuild a Topology Type
  2. On the Domain Management page, click Data Accuracy Resolution on the Start Page.
  3. On the Data Accuracy Resolution tab, click Topology Link Manager on the left pane.
  4. In the Topology Link Manager, select the topology, and click  to select Rebuild Topology from the drop-down menu.
    Graphical user interface, text, application, chat or text message, email
    Information Note: The topology links in the manually created zones cannot be updated by running a benchmark task or Qapp.
    Information Note: For Build Both Topo and Open Topo, the system will first calculate the old topology and then the open topology. As a result, the open topology result will overwrite the old topology and be used in the system. The old topology will be saved and used when using the Compare Topology plugin.
