Quick Intent
Quick Intent is a function that enables power users to create intents by defining simple diagnosis based on the current map devices.
- Collect Data: Select target devices and enter commands to retrieve device data.
- Apply Parser: Directly select a parser or new a parser to parse the retrieved data.
- Define Logic: Define diagnosis to detect the changes.
- Target Device: Select the target devices and duplicate the current diagnosis to these devices.
- Run Intent: Execute the intent and view the execution result on the map.
