Map Intent
Users can associate an intent with a map page to document the key design or the primary troubleshooting steps. By embedding an intent in a map page, users can have the map page and intent work side-by-side and promote a simple power-user workflow: Create an intent for a map page and then use the intent while using the map page.
Note: A map page can only have one Map Intent. |
