Manage Incident Type
Manage Incoming Incident Type:
- Click
and select Triggered Automation Manager.
- Click the Incoming Incident Type tab.
- Select an Incoming Incident Type, and click
You can:
- Edit, delete and test this incident type.
- Export this incident type to a local file.
- Move this incident type up, down, to top, and to bottom.
Note: As the incident types are grouped by their source and category, the incident type can only be moved within their source. Note: The system will match an incoming API call to Incident Types according to the order. - Define the Interactive Trigger for this incident type, so the incoming incident type can also classify sources from Email or self-service.
- To export all Incident Types, click
To import an incoming incident type from a file (in .XIT format), click Import from the drop-down menu or > Add Incoming Incident Type … > select a local file in the pop-up window.
Manage Virtual Incident Type:
- Click
- Click the Virtual Incident Type tab.
- Select a Virtual Incident Type, and click
You can:
- Edit and delete this incident type.
- Export (or Click
) this incident type to a local file.
To import a Virtual Incident Type, click Import from the drop-down menu or > Add Virtual Incident Type … > select a local file in the pop-up window.
