Manage Tenants
Users with the privilege of system management can view and manage the tenants in the system.
To view and manage the tenants in the system, do the following:
- Log in to the System Management page.
- On the System Management page, select the Tenants tab. The tenants created in the system are listed on the page.
- Select a tenant and select Edit from the drop-down menu.
Tip: You can select Delete from the drop-down menu to remove a tenant from the system. |
- Define the settings in the pop-up window:
- Basic Information: Specify a tenant name and enter descriptions for the tenant.
- License Allocation: Allocate network module license and function module license to the target tenant.
- Assign Users: Assign users for this target domain. For each assigned user, you can set the user privilege by enabling the Tenant Access or Tenant Admin check box.
- Click OK to save the settings and create the tenant.
