Export Usage Report
Usage Report records the login details of system users, such as first login time, last logout time, and total online time.
To export the usage report, do the following:
  2. On the System Management page, select the Usage Report tab. The user accounts logged into the system within the specified period are listed. You can filter the entries in the Usage Report by Tenant, Domain, or setting a Period.
    Graphical user interface, application, table, Excel
Information Tip: The Total Online Time is not simply the sum of logged-in time duration that the user spends in the system. If the user has logged in to multiple domains concurrently, the overlapping time contributes to the total online time only once.
  1. Click Export to export the usage report. The default location of the exported file is C:\Users\<your username>\Downloads.
Information Tip: To browse the detailed user login records, click Check Details in the corresponding entry. The usage details can also be exported by clicking the    icon in the pop-up dialog box.
