Manage Knowledge
Manage Knowledge Document
You can write a document in Insight Manager so LLM can leverage the knowledge for inference. The LLM will find a matching document based on the user’s query, then use its content to determine the response and search for relevant automations.
  1. Select the device type to be qualified for the document.
  2. Enter a description.
  3. Write your document in the Content text box.
