Enable GCP APIs
NetworkBrain System requires access to the following GCP APIs:
  • Compute Engine API
  • Cloud Logging API
  • Cloud Resource Manager API
  • Cloud DNS API
  • Service Usage Viewer
  • Stackdriver Monitoring API
Follow these steps to enable the required API libraries:
  1. In the GCP Console, go to the API Library page.
  2. Search or browse the library to find the required APIs like Compute Engine API.
    Graphical user interface
  3. Select Compute Engine API to open it. Click ENABLE.
  1. Repeat steps 2 and 3 to enable all other required APIs.
