Edit Diagnosis
The Diagnosis entry in the bottom-right table can be edited or deleted. When a Diagnosis entry is selected for editing, its current definition will be loaded into the 'Apply Parser' and 'Define Logic' sections for further modification.
 When ‘Compare with Baseline’ is selected, you can directly define the baseline settings at the intent level, automatically updating the intent baseline.
