Discover Kubernetes Cluster
This topic describes how to add a Kubernetes API server and discover the Kubernetes Cluster.
Add API Server
Navigate to the Domain Management page and open API Server Manager.
Click + Add API Server and define the following fields:
- Server Name: a unique name.
Description: an optional field to describe this server.
- API Source Type: select the Kubernetes Cluster.
Endpoint: Kubernetes Master node IP/URL with port 6443.
Note: The endpoint should be the Kubernetes master node IP or URL with port 6443. If a Kubernetes cluster has more than one master node, you only need to add one master node IP as the endpoint. Adding more than one API server for a single cluster will cause problems in the system. - Auth Token: use the authentication token copied during the setup of Setup Kubernetes API Access.
Front Server/Front Server Group: select one front server which can access Kubernetes.
Click OK to add API server.
Discover the Kubernetes Cluster
Once API Server is added, you can discover the Kubernetes Cluster in the Discover tab.
- Click the Discover link from the Domain Management page.
- Click + Select API Servers and select the Kubernetes API Servers you just created.
- Click Start Discovery to start the Kubernetes discovery.
- Wait till the discovery finishes. The number of discovered objects will be displayed.
