Logo
Define Applications
The Application Manager is used to manage, monitor, and verify applications and paths. In the first step, document the applications and paths in the Application Manager. Then, you can schedule the task to verify the applications. For details on defining applications and paths, see Define Applications and Paths and Define Golden Paths.
Application Assurance Module Define Applications and Paths
