Default Data Source
You can set a default source for a Qapp so that you will not have to reselect the data source each time when you run the Qapp.
To specify the data source for a Qapp:
- On the Execution Flow tab, click the
icon.
- In the Run Options window, enable the required data sources and define the default one for the Qapp:
- Current Baseline — the latest device data saved in the system.
- Live Regularly — log in to the device to retrieve live data regularly based on the customized frequency. You can check the Repeat checkbox and enter a number to set the execution times for this Qapp.
- Live Once — log in to the device instantly to retrieve live data for once.
- History time period — select a time period.
- History time point — select a time point.
