Creating a Qapp to Monitor Device and Interface Parameters
Monitoring is one of the most frequently used functions of a Qapp. You can use Qapps to analyze retrieved data and show real-time results on a map, including live performance data and alerts.
This section will start with a simple use case ‘monitor device CPU usage in a map’ to guide you to create a monitoring Qapp step by step.
Complete the following three steps:
  1. New a Qapp.
  2. Define Canvas to Retrieve and Parse Data.
  3. Save and Run the Qapp.
