Creating a Network Change Template
- Create a network change runbook.
- In this network change runbook editor, click the
icon and select Save as Template to enter the change template editor.
- Define the template variables for the change template. See Template Variable for more details.
After defining the Network Change Template information, click Save, select a location in the pop-up dialog, enter a name, and click OK.
