Clean Domain Data
The more automation tasks the system performs, the more data will be retrieved and generated. Generally, the data includes the following two types:
  • Device data, such as configuration files, route tables, original CLI data, golden baseline data and parser data.
  • Task data, such as Qapp/Gapp execution logs, benchmark/discovery execution logs, One-IP table entries and so on.
The system provides the definitions of auto-clean rules for data at the domain level.
To customize the auto-clean rules for your domain data, do the following:
  1. On the Domain Management page, click the  start menu and select Global Data Clean Settings from the drop-down list.
  2. On the Global Data Clean Settings tab, make modifications based on your needs.
    Category
    Default Auto-Clean Rule
    MongoDB Data>Data Engine Data
    (Device data, such as configuration files, route tables, CLI commands, and parser data)
    Information Tip: You can manually delete the data for the specific month(s).
     Only keep 2 data points for each data type in a month for data older than 4 months.
    Note: The number of months must be between 0 and 65535. If you enter 0, the system will only keep the data in the current month and delete all aged data.
    Delete data older than 6 months
    Front Server DB Data:
    • CLI Command and Config Data
    • Monitoring Variable Data
    Only keep 2 data points for each data type in a month for data older than 1 months.
    Delete data older than 3 months
    Other Data
    (Task data)
    Information Tip: You can use the Clean Now button to clean the existing data immediately.
    Qapp/Gapp Execution Logs
    Delete data older than 14 days
    One-IP Table Entries
    Note:  The data source of One-IP Table Entries comes from executed benchmark tasks or rebuilding L2 topology manually.
    Discovery/Benchmark Logs
    Application Path History Data
    Data Unit Storage
    (historical data views generated by Qapps being executed in the Schddule Qapp, Dashboard and Map functions)
    Information Note: The Clean Now button is not available for this data.
    Delete data older than 1 months
    Backup Maps
    API Triggered Automation Task
    Triggered  and Intent Embedded Incidents
    Event Entries in Event Console
    Execution Logs for Scheduled Data View Template
    Dashboard Activity Data Table
    Compare Results
    Third Party Flash Alert
    Feature Intent Template Execution Logs
    Adaptive Polling Result and Flash Alert
    Triggered Diagnosis TaskDelete data older than 6 months
    Platform Validation Logs
    Network Intent Execution Result
    Global Auto-cleaning Settings.
    You can navigate to the settings by clicking this hyperlink.
    Network Intent Template Execution
    Network Intent Template Cloned Intent
    Automation Data Table Execution Log
    Delete data older than 14 months
  3. Click Save.
