Build Column Group with CLI or Config File Data
ADT Dataset method is to build ADT Dataset with CLI or Config file from device, adding device configuration files and CLI commands as links into dataset column, serving as data source for intent creation, intent decoding, intent replication, and intent execution. The ADT dataset can be created by using four types of data source. For more details, see Build ADT Dataset.
