Assign a Proxy Server to a Front Server
Each Front Server can only support one Proxy Server. There are two ways to assign the Proxy Server to the Front Server:
Option 1:
- Navigate to System Management > Proxy Manager.
- Click the downward arrow aside the desired Proxy Server and select Apply to Front Server.
- In the Apply to Front Server window, select the desired Front Server.
- Click OK to assign the Proxy Server to the Front Server.
Note: Only the Front Servers already registered (the registered status is Yes) are allowed to be assigned with a Proxy Server. Tip: You can simultaneously apply a Proxy Server to one or more Front Servers.
Option 2:
- Navigate to System Management > Front Server Controllers.
- Click the downward arrow aside the desired Front Server in the left pane, and then select Edit.
- In the Edit Front Server window, select a Front Server Group and the Proxy for the current Front Server according to your needs.
- Click OK to apply the above changes.
