All Runbook Templates
Power users can access the Runbook Template Manager to browse all runbook templates. They can view existing templates or create new ones.
  • Shared Runbook Templates — contains runbook template files accessible to all users in this domain.
    Information Note: A default template is provided for you to create a runbook.
  • My Runbook Templates — contains runbook template files only accessible to yourself in this domain.
You are allowed to perform the following actions:
  • Filter the RBTs by current map/tag.
  • You can select a node to view its information below. The number of the runbook input variables is also displayed.
  • You can also perform the following actions for the RBT folder and runbook template.
