Add-on Parser
Based on the auto parser concept, the current parser use flow and parser definition are optimized. If the parser pattern is determined (by directly creating a new parser pattern or confirming the parser definitions in Auto Parser) before making other parser definitions, the add-on parser function is launched to complete defining a parser.
The UI components for add-on parser mode (the UI is a sample paragraph pattern) are shown below:
With the add-on parser function, you can define nine types of parser patterns.
- Single-variable parser
- Paragraph parser
- Table Parser
- Collector Parser
- JSON Table Parser
- Dependency Pattern
- Merge Table
- Append Table
- Aggregate Table
