Insert Hyperlink on Map
You can insert different forms of hyperlinks on map for a quick access. The option Hyperlink is available in the Stencils menu for adding a specific website address / Network Intent / ADT.
Follow the steps below to add a hyperlink:
- Open the Stencils menu.
- Click the Hyperlink to open the Insert Hyperlink window.
Select the type of hyperlink you want to insert:
- Manual Input: This is a default type, and it is provided to manually add a specific website address in the URL field.
- Network Intent: The option is provided to add a Network Intent as a link to open from the map. When you click on the hyperlink, it will directly open the view interface of that intent.
In the URL field, click Select Intent to open the standard intent selection window.
- Automation Data Table: The option is provided to add an ADT as a link to open from the map. In the URL field, click Select ADT to open the ADT window for selection.
- Display Text field: Input the text to display as hyperlink on the map. If it is empty, the URL will be directly displayed on the map.
Click OK to save and close the window.
Note: The displayed hyperlink can be edited or deleted from the map using the right-click menu.![]() |
