Access Credential for Telnet/SSH CLI, Smart CLI and Change Management
Specify to use the private or shared credentials for SSH/Telnet CLI access, Smart CLI access and network change management.
OptionDescription
Use Private Credentials and Shared Privilege Credentials (default)Use the credentials defined in the Private CLI Settings to log in to devices and then use privilege credentials defined in the Shared Device Settings to enter the privileged mode.
Use Private Credentials and Private Privilege CredentialsUse the credentials in the Private CLI Settings to log in to devices and then use privilege credentials defined in the Private Device Settings to enter the privileged mode.
Use Shared Credentials and Shared Privilege CredentialsUse the credentials defined in the Shared Device Settings to log in to devices and then use privilege credentials defined in the Shared Device Settings to enter the privileged mode.
