Viewing Plugin Execution Status and Logs
After executing a plugin, you can view the execution status and logs.
As an additional operation of a scheduled task, the status of a plugin impacts that of the scheduled task as a whole.
- Impact to Scheduled Plugin Status:Plugin StatusScheduled Plugin Status
(All Plugins) Succeeded Succeeded (All Plugins) Failed Failed (Some Plugins) Succeeded Succeeded with warning
- Impact to Benchmark or Discovery Status:
Plugin Status Benchmark/Discovery Status (All/Some Plugins) Failed Succeeded with warning (if the left modules of the benchmark/discovery succeeded.) (All Plugins) Succeeded Depend on the status of other modules
Viewing Plugin Execution Logs
Proceed with the steps below to view the execution logs of a plugin in a scheduled task:
Note: The printed execution logs of a plugin depend on the log definition in your plugin script. |
Example: View the plugin logs in a benchmark task.
- On the Domain Management page, click Schedule Task.
- On the Schedule Discovery/Benchmark tab, right-click a benchmark task and select View Result.
- In the View Log pane, click the
icon in the Log column.
- View the plugin logs in the Plugin Log pane.
