View Domain Health Report
The domain administrators can leverage the Domain Health Report to accelerate the tune-up phase (customization for topology/path data accuracy) before delivering a fine-tuned domain to end users. The report provides key factors and more detailed statistics about domain health. As a benefit, the domain administrators can get an overview of the current domain status, proactively focus on the items that need their attention, and resolve the potential problems in a domain as early as possible.
The domain health report is generated on-demand and contains a summary and various categories.
To view the domain health report,
  2. On the Domain Management page, click  and select Health Report from the drop-down list.
  3. In the Domain Health Report tab, click Create Health Report to generate a report.
  4. View the highlighted area to get an overview.
  5. Check the following areas to get more information.
Driver Associated Device
The following table displays the count of devices discovered by corresponding drivers. The device driver defines the method of retrieving and parsing device data during live access.
Information Note: See Device Driver for more details.
Basic Network Settings Completeness
The table lists the information in Network Settings, API Server Manager, and CheckPoint OPSEC Manager.
IndexDescriptionCondition Calls for Attention
Stand-alone Front Server (defined)The count of stand-alone Front Servers served in a domaincount = 0
Stand-alone Front Server (unused)The count of stand-alone Front Server that is allocated with 0 devicecount > 0
Stand-alone Front Server (with over 5000 devices)The count of stand-alone Front Server that is allocated with more than 5000 devicescount > 0
Front Server Group (defined)The count of Front Server Group served in a domainN/A
Front Server Group (unused)The count of Front Server Group that is allocated with 0 devicecount > 0
Front Server Group (with over 5000 devices per Front Server)The count of Front Server Group that is allocated with more than 5000 devicescount > 0
***1) (defined)The count of defined ***count = 0
***1) (unused)The count of *** with 0 devicecount > 0
API ServerThe count of defined API ServerN/A
CheckPoint OPSECThe count of defined CheckPoint OPSEC
  • count = 0 when there is CheckPoint R77 in a domain
  • No mark is required if there is no CheckPoint R77 in a domain
Information Note: 1) *** represents Private Key, Jumpbox, Telnet/SSH Login, Privilege Login, and SNMP String.
Discovery Status
The table lists the discovered device summary and licensed node usage.
Licensed Node UsageThe usage of the licenseN/A
Fully CLI-Accessed RateThe rate represents the percentage of Fully CLI-Accessed Devices among All Discovered Devices, except Don't Support CLI devices and other devicesN/A
Fully CLI-Accessed DevicesThe devices that the system discovered via CLIN/A
Latest CLI Configuration Retrieval Failed Devices
The devices that NetBrain successfully retrieved configurations via CLI before but failed to update CLI configuration in the last attempt
count > 0
SNMP-Only DevicesThe count of devices in Data Accuracy Resolution > All Discovered Devices > SNMP-Only Devicescount > 0
Unknown SNMP SysObjectIDThe count of SysObjectID in Data Accuracy Resolution > Unknown SNMP SysObjectIDcount > 0
Devices to be Discovered
The count of IP addresses in Data Accuracy Resolution > Devices to be Discoveredcount > 0
Inaccessible DevicesThe count of devices in Data Accuracy Resolution > Inaccessible Devicescount > 0
Subnet with Conflicted IPsThe count of subnets in Data Accuracy Resolution > Duplicated IP and Subnet Manager when All Zones is selectedcount > 0
ZoneThe count of Zones in Data Accuracy Resolution > Duplicated IP and Subnet Manager
count = 0
Note: Because of the existence of Default Zone, the count of Zone cannot be equal to 0.
Hostname ChangeThe count of devices with hostname changed in Data Accuracy Resolution > Hostname Changecount > 0
Site Definition Completeness
The table lists the summary of site information.
Container SiteThe count of Container SiteN/A
Leaf SiteThe count of Leaf SiteN/A
Leaf Site (with 0 device)The count of Leaf Site with 0 devicecount > 0
Leaf Site (over 100 devices)The count of Leaf Sites with more than 100 devicescount > 0
Unassigned DevicesThe count of unassigned devicescount > 0
Benchmark Task Health
The benchmarks whose results display as Succeeded with Warning or Failed will be marked within the Attention column.
Cloud Health
This area shows the basic information of the existing clouds in the current domain. Blank NCT includes those tables with headers only. When the count of blank NCT exceeds 0, the attention icon will display.
Path Calculation Health
This area shows the summary of path calculation, such as the count of total paths, the count of successfully calculated paths, and the count of not calculated paths. The Path Result Category column is categorized by Succeeded and the causes of failure.
Disk Management Settings Completeness
Global Data Clean Settings
The table lists whether or not the data in Global Data Clean Settings is enabled.
IndexCondition Calls for Attention
Data Engine DataDisabled
Qapp/Gapp Execution LogsDisabled
One-IP Table EntriesDisabled
Discovery/Benchmark LogsDisabled
Application Path History DataDisabled
DataUnitStorageDisabled
Backup MapsDisabled
API Triggered Automation TaskDisabled
Triggered and Intent Embedded Incidents
Disabled
Event Entries in Every ConsoleDisabled
Execution Logs for Scheduled Data View Template Disabled
Dashboard Activity Data TableDisabled
Compare ResultsDisabled
Third Party Flash Alert
Disabled
Feature Intent Template Execution Logs
Disabled
Adaptive Polling Result and Flash Alert
Disabled
Triggered Diagnosis Task
Disabled
Platform Validation Logs
Disabled
Network Intent Execution Result
Disabled
Network Intent Template Execution
Disabled
Network Intent Template Cloned Intent
Disabled
MongoDB Disk Alert Rules: (System Settings)
The table lists the settings of MongoDB Disk Alert Rules in Service Monitor.
Type
Send emails when alert detectedWhether to be enabledDisabled
Send emails and delete Data Engine data when alert detectedWhether to be enabledDisabled
Send emails and disable write permission to MongoDB when alert detectedWhether to be enabledDisabled
Email AddressWhether to be configured
When the Email Address is not configured, at least one of the above rules is configured.
Note: If the Email Address is configured, the status is Configured. Otherwise, the status is None.
Map Layout Settings Completeness
The table lists the information in Map Layout Manager.
Customized LayoutThe count of customized layouts in Layout Styles and Sample Maps, except for built-in layoutscount = 0
Devices with Tags AssociatedThe count of devices with tags assignedN/A
Devices without Tags AssociatedThe count of devices without tags assignedcount > 0
Site Maps with Layouts AssociatedThe count of sits maps with layouts associatedN/A
Site Maps without Layouts AssociatedThe count of sits maps without layouts associatedcount > 0
