Verify Applications
After defining the application and golden path, you can verify the application path regularly. And each time when the system periodically verifies or monitors the path, it will compare the results with the Golden Path to detect changes. The calculation and comparison results can be viewed in Application Manager. Moreover, you can verify application paths via Runbook by adding a Verify Application node.
