Searching for Sites
There are two ways to search a site, one from Global Search and the other from Site Taskbar.
From Global Search
  1. Enter keywords of the Site in the Global search bar, and click Enter to start searching.
    Information Note: Global Search doesn’t support Site Name search, but supports Site device name search.
  2. By default, device results will be shown first. Click  to close the drop-down list and open the Site drop-down list.
Graphical user interface, text, application, email Description automatically generated
From Site Taskbar
  1. Click Site on the taskbar to open Site pane.
  2. Enter a Site name in the Site search bar to locate a site.
    Information Tips: if you want to search a device by the hostname, enter the partial or full hostname in the Search Bar at the top of the devices (right pane).
  3. Press the Enter key on your keyboard to start searching. The search results are displayed with the matched keyword highlighted.
